Discuss Outdoor Flex Cable RR-F or RN-F in the UK Electrical Forum area at ElectriciansForums.net
Just as a little extra....
I still haven't got to the bottom of why H05RN or H07RN is classed as more appropriate for outside use than RR. I am specifically talking about the neoprene inner sheath/jacket of the RN as opposed to the rubber inner sheath/jacket of the RR.
However, since writing the above 20 minutes ago I have done a little research on the net. Neoprene is in fact a rubber, a synthetic rubber. In particular neoprene 'resists degradation more than natural rubber' (Neoprene - Wikipedia - https://en.wikipedia.org/wiki/Neoprene). It is relatively inert meaning it does not react with many things, more accurately it is in a 'state of doing little'.
So, in layman's terms I guess we prefer RN as opposed to RR for 'certain' outdoor situations as it lasts longer.
I believe water can slowly penetrate the R rubber (EPR) whereas the N rubber, neoprene (polychloropene) the migration is imperceptible.
Therefore where a cable is constantly wet, such as in a pond, the EPR would not be suitable and would fail after a few years, where the cable is say on an outside wall the water will dry off before it can penetrate.
That makes sense Richard with regards the use of neoprene, but what about the outer insulation (R) on RN cables? With your above example would this not fail after a few years if constantly wet in a pond?
The RN cable still probably lets the water in under the primary insulation (Rubber) but the neoprene would maybe stop the further migration of water.
Whereas RR cable the inner conductor would probably corrode due to the water migrating through both rubber insulators.
Insulation is EPR (R), outer sheath is neoprene (N), now thinking about it it is not suitable for continuous immersion just for wet areas, I think.
If you have a RN cable where the junction box gets wet then the water can track up the inner rubber insulation and wreck the cable.
I am sure someone posted a useful post on harmonised cable classification a while ago, giving clarity to the numbering system, I think they were called happyhippydad;)!:)
Reply to Outdoor Flex Cable RR-F or RN-F in the UK Electrical Forum area at ElectriciansForums.net
I have 2 outdoor floodlights & and pond pump. Each came fitted with H05RN-F cable. I've looked at 4 cable suppliers' web sites. 2 of these say...
I have some PECSO HO7RN-F 3G1.5 Flex cable that i want to use to wire up some outside LED security lights that are 240v. The cable will be clipped...
Hey guys, looking for a bit of advise on the installation of an outside light. I plan on chasing out the plasterboard and running a cable from a...
Hi The ground floor of my house has two lighting circuits which are each protected by an MCB. One of those circuits is just indoor lights. The...
4K
Hi all, I’m now ready to install my hob, I have a 32A MCB with 6mm T&E feeding a 50A rated switched supply at the worktop. The hob isn’t supplied...
