Discuss Outside lights required at end of garden in the UK Electrical Forum area at ElectriciansForums.net
Gary C
I need to install some outside lighting at the far end of the father in laws garden (brownie points available here!). They have existing power outside (sockets only). The preferred method is to run the cable along the side wall down to the required position.
Please could i have some advice on the best methods for this:
- Connection into existing indoor lighting circuit? - RCD protected?
- Type of cable - Armoured or run in conduit (metal, plastic?)
- Regulations that i may be missing?
- Any other advice that you may have?
Realise these are quite basic questions but having only just passed electrical exams, some of the more practical information is lacking
If you have sockets available then the easiest thing would be to get a string of plug in lights, but get one with a separate transformer so you can get the plug in the socket.
30mA RCD protection is always a good idea but not required (yet) for surface run cable or outside lights.
Armoured cable if there is the chance of damage, heavy duty flex if not.
Read section 714 and 715 of BS7671.
or wait for Santa to send his elves round. :rolleyes::rolleyes::rolleyes:
The sockets are at the wrong end of the garden as well.
So assuming the indoor lighting circuit is suitable to add the additional external lighting, i can add an additional switch to the existing and feed direct to the light/s
Reply to Outside lights required at end of garden in the UK Electrical Forum area at ElectriciansForums.net
Hi Gents, I am thinking about running some cables in the garden. The idea is to electrify the garden. My idea is to run some electrical cables...
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
Hi, I’m new to the forum and am seeking some advice please. I’ve picked up a job that another electrician has abandoned, the job is to...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
