Discuss Periodic Inspection Query in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
S
Sav
Hello people,
Hope everyone is well and busy !!
Just a quickie ( Oooh er missus ):D:D
I am going to do a periodic on a flat on Friday. The main incoming supply is a TNC-S supply and 3 phase supply.
Now on the cert, would you put down as number and type of live conductors 3-phase (2 wire) ??
And for "Characteristics of primary supply overcurrent protection device(s)", would I be correct in writing down BS1361 type 1 100a, as this is the fuse supplying power to the flat I am testing.
From there it goes into a Wylex 60a isolator and then approx 10m into the flat c/u. I know about doing the Zdb for the distribution circuit etc, its just the 1st part I get confused about.
Thanks for your help in advance,
Sav
:D
Although it is a three phase supply to the block, I presume that only one phase is used for the supply to your customer's flat through a single phase meter. In this case I would put single phase, 2 wire on the cert. I would only record it as 3 phase it the customer is actually provided with a 3 phase supply, i.e. they have a 3 phase meter.
Reply to Periodic Inspection Query in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
I am in the middle of installing a new 3 phase system for a small bakery production area, new building, 200 KVA supply in total. 200 TP for...
Hi there I preface this query with: I am an almost complete electrical novice. I need to control the speed, startup and slow down of a 2100W...
Landlord has had an EICR done on the property as is required under the new PRS legislation, got a copy of the report and I'm not overly impressed...
I am installing a micro-brewery in our barn in France; as you can guess that, means that I am a brewer, not an electrician :-) I did 'fess up to...
