Discuss Pulling the cable sorted the problem in the UK Electrical Forum area at ElectriciansForums.net
1stfix2ndfix
I was working as an electricians mate the other day and there was this one light that when turned on kept tripping out the rcd. it was the one at the top on the stairs and was a two way with the one down below sort of thing. I cant remember if it would do it no matter if you used the bottom switch or the top to turn it on but im pretty certain it was only the top as thats where he headed after having me whip the bottom switch off to have a look for anything that might of been pinched. Well after sitting by the cu for a bit flicking the old rcd back on and on lol Im convinced the cable must be have a nick in it somewhere and thus there is no insulation resistance and also for some reason im thinking it can only be on the neutral although i don't know why I think this as if there was a nick on the live it too would mean that what was going out still wasn't coming back but ill put it in there for educational purposes. I was also thinking that this means we need to take that cable out and put a new one (keen and all that!) as its been damaged and in my heAd now the metal conduit we used to pull them down has become live so so has the wall which if they had wet hands and touched might tingle more then with not, again i dont know why i think this i just do and if my mentor is unfazed it must mean im completely wrong but im sure something is up there. Literally a pull on the cables fixed the rcd tripping problem. No testing was done to identify anything on the problem side of things it really was a case of jiggling the cable Although a certificate was issued.
Is it literally a case of no thats fine as the rcd isnt tripping out and the tests carried out conformed with that required to give it a certificate.
All testing was carried out at the board except for me going to the lighting points and taking a earth loop impedance reading and visa versa for the sockets
What was making it do that and whats made it stop, is anyone willing to edgimicate me please
So a cable was damaged but some slack on it was pulled through and tests confirmed the fault had cleared?
Is that the case?
Yeah basically mate although this happened midway through the next day after all the main jobs had been done on the re wire. It was working fine the day before. I don't think it was re terminated or anything just literally pushed pulled and jiggled. No testing was done after it was fixed other then the fact the rcd didnt trip just wondered what happened and what does pinched mean lol
If edgimicating you is like disembowelling you with the blunt end of a sharp instrument I'm up for it! :)
Pinched is what happens to your tools when you leave them lying about unattended.
Reply to Pulling the cable sorted the problem in the UK Electrical Forum area at ElectriciansForums.net
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
Can i just check something. If a rat decides to chew a cable will it trip the MCB or RCD ? I ask because I had one house recently that had a...
I got a TEXT message (i dont know them and i cant find out who they are from the phone number) "Hi speaking from Indeed Are you available to give...
