Discuss RCD being used as a main switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Is it against the regs to use and RCD as a main switch ? I have been told it is but Im struggling to see anything that confirms so. Im looking at 314.1 in the regs book but that doesn't say anything about an RCD being used as a main.
Any feedback would be greatly appreciated.
Sorry, as its a Bank Holiday being a bit flippant. You could use an S Type RCD as main switch on TT supply, as it negates issue of internal single insulated manufacturers tails on dual RCD's, shorting on metal enclosure. You could use a 30mA RCD as main switch on small garage CU etc. But if you used a 30 mA on larger installs, it would (not) provide very good division of services, would it?
Edit
As lee says its about avoiding disruption from nucence tripping i think there is a reg number for that , so try looking in the regs book for that
I know its going to cause nuisance tripping and not ideal but I am was looking for a reg to back up that its not correct. We are doing inspections and have been told to pull it as being a Life health safety issue. Thats the term they use out here for a C1. Would any of you back home write it up as a C1 ?
Absolutely NOT
C3 maybe but I think you would struggle to justify that.
How can there be a danger to life or property due to the main switch being an rcd, remember as others have said some installations have to have an rcd as a main switch , the most it would get is a code 3 or just info
Whilst trying to justify some sort of reason for a perfectly healthy electrical system,it was suggested that Granny could tumble down the stairs in the dark and meet her maker ( her faulty Teasmade failed to make the late night cuppa)
The moral of the tale is that Granny should not rely on a single Rcd or she may be safer drinking squash
When one Rcd was the norm,the terrible danger should have been made known to the 100% who managed to survive ;)
Coding is down to the inspector of the installation.
If you feel strongly that a rcd main switch gives potential danger then code it.
If you think it's inconvenient at best but isn't a safety issue note it on the eicr.
An rcd tripping causing loss of power to the upstairs lighting can still occur with a dual rcd db yes hopefully the upstairs sockets aren't effected and a bedside lamp can be used for lighting.
Reply to RCD being used as a main switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi there, Any advice on this would be greatly appreciated! (Note, this is not a DIY, I'm using a fully qualified electrician, just posting here...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
hello guys, hope you’re all well. We are looking at installing the Hager SFT240 changeover switch to three live aboard boats with an electric...
