Discuss Rcd testing in the UK Electrical Forum area at ElectriciansForums.net
Iona222
Trainee
Is a shower rcd, arranged ro the side of the ccu. What the correct procedure.
I'm earth on earth bar, neutral on bottom left on rcd, and live on top mcb. The rcd is just tripping once, says trip on the megger.
Should I do it inside the shower?
you should test the RCD at the RCD itself, with load disconnected
You need to test the outgoing line and the outgoing neutral, with the earth on the earth bar.
The way you describe it, it would seem that you are testing the outgoing neutral and the incoming live. No wonder it trips.
What make of board is it?
Is this a split load board?
Maybe a pic would help...
That the board, do on the bottom neutral of the rcd and bottom of the mcb?
Well there’s a pointless shower isolator.
yes bottom neutral of rcd and bottom line, which is also bottom of mcb via busbar. Mcb off. Earth on earth
what tester are you using, and what setting?
It shouldnt trip at 1/2 x I
It should at x1 and x5
30mA setting?
Reply to Rcd testing in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Been a while since I have been on here. I have been on an apprenticeship the last 3 years training in the BMS world. Taking that into...
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
Cant get my head round this :( I understand N-E faults cause RCD's to trip, but I cant understand why on these 2 occasions, googled allover but...
I just finished a garden room supply. The customer already had a CPN garage consumer unit that the last sparks left there, brand new in box, and...
Given the RCD pictured below With the manufacturers instructions here: Am i right in interpreting that as well as being able to bring the...
