Discuss Relay for spotlights in the Auto Electrician Forum area at ElectriciansForums.net
Yes it works.I’m not an auto electrician so switching (neutral) in house electrics is a no no. But look at your vehicle. Surely just about every circuit switches the live. Have a look at your horn, windscreen wipers, heater blower, EVERYTHING is switched live.
Maybe a petrol head can Comment?
Agreed, switching neutral is completely unacceptable in LV eg houses, where dangers around touch voltages exist.
In the automotive world, low side switching is super common especially in modern cars where most items are computer controlled. Generally this is for the following reasons:
1) N channel transistor switching is easier*.
2) fusing arrangements for low side switching are often more practical.
I'm sticking with my original answer of "it's fine, pay attention to the risks in this situation which relate to fusing, not which side is switched."
All the best,
*Long story.... Look up an electronics article on low side vs high side transistor switching if you're interested.
Agreed, switched ground for relays and other automotive items is quite normal and safe.
Some examples of such things being standard are
Door switches for lights (already mentioned)
Horn on most cars
Fan thermostat
Points on cars old enough to have them
Thanks. Every day’s a school day!
Before cars had 314 different buttons on the steering wheel, there was one slip ring and brush behind the wheel that brought the ground wire from the horn to one terminal of the horn press switch.
The other terminal was simply grounded to the steering column.
Thanks everyone for your input. I am aware that the horn works by grounding to earth but I guess with the high draw needed for the spotlights I am still wondering about using the ground to switch. More research on my part needed!
There’s minimal current passing through the switch, it’s only operating the relay. That is what the relay is for.
As above, you must have a fuse in the 12v feed to the relay. How big will depend on the load of the spotlights.
Reply to Relay for spotlights in the Auto Electrician Forum area at ElectriciansForums.net
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
I'm looking for an LED spotlight that can be mounted on an existing lighting column. The aim is to illuminate a war memorial that is 20m away...
Greetings. I am new to this forum and I have a question regarding a relay that I am installing on a motorcycle wiring harness. What I'm trying to...
Hi guys, im currently trying to start my new big block chev in a chevelle but having issues.. im a full novice on electrics so be gentle ! The...
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
