Discuss Replacing supply to garage in the UK Electrical Forum area at ElectriciansForums.net
Hi there.
I am not an electrician and ask this question of your forum.
My house needs rewiring as the cables although not perished are the type fitted in the 1960s and the lighting circuit is not earthed. The house CU is around 20 years old(Professionally installed) and the house is protected by a RCD between the Meter and CU, so if it trips the whole house supply is shut off.
I have lived in the house for over 35 years and one of the first jobs I undertook when moving in was to run a supply to a detached garage for a light and a double socket.
At the time I ran the supply cable in 2.5M twin and earth and to reach the garage it was buried in steel conduit.
Well time has moved on and having read all about Part P and the like I am aware of the need to have a qualified electrician carry out CU work and new circuits.
As mentioned it is my intention to have the house rewired late this year which will include work within the garage.
My issue is around some work I am having carried out on the garden which will result in digging up the area near the garage.This will enable me to replace the old supply cable with 6mm 3 core SWA.
Obviously I would like to connect this cable to the small junction box I have in the garage and the other end to the CU.
In the garage, from the junction box I installed a 6A fuse switch for the light feed, the double socket sits protected by the house CU trip switch which is 16A.
I appreciate a new CU will have the built in RCDs when replaced along with a CU in the garage
In preparation for the amount of work I will undertake in the house renovation I am looking to instal another twin socket for tool charging and running small power tools from the socket (chop saw)
The question I ask is am I allowed to instal the SWA myself and not breach the Part P regulations and not need a certificate.
I will be earthing the SWA at the house CU both from the core cable and the SWA outer covering.
Many thanks in anticipation for any advice.
You need to inspect, test and certify in accordance with the wiring regulations regardless of whether part P notification is required or not.
Inspection and testing is an essential part of compliance with the wiring regulations and without carrying it out correctly you could be left with a dangerous installation.
PG can I suggest in order to do the job you require safely you employ the services of an Electrician, it will be safer and more benificial for you in the long run.
I'm all for saving money where possible , but in this case, you need proffesional help, and good luck.
If you intend a full rewire later in the year then carry on with the 2.5 which exists and when you hire the electrician to rewire, work with him/her to dig and install the calculated cable. They will have seen 1st fix and second and test it to add to your certificate of electrical loveliness and notify.
Ps that is possibly the nicest avatar I’ve seen in a long time and not a pet in sight, except for the chick of course!
The ideal solution for a new cable to the garage is directly from the house CU to the new garage CU....... avoiding ALL unnecessary joints
As for fuseboards - save up a little extra and have a RCBO board fitted.
My advice to you is to get a spark engaged, sooner rather than later...
Many thanks for the quick responses. OK shall get someone to carry out all the fix at rewire have .
As the dig is taking place from tomorrow it is sensible to lay the SWA and then back fill ready for electrician to connect up in due course. ( having the patio and drive block paved) do not want to dig this up later
From some of the answers am I understanding that the electrician would need to lay the SWA or would they just see that its installed. I am digging down .75m to lay will sand and cover with cable notice.
any sensible plastic tube will suffice. for a 6.0mm SWA cable, something with an internal diameter of 1" is fine, but no sharp bends.
Reply to Replacing supply to garage in the UK Electrical Forum area at ElectriciansForums.net
Hi I currently on a job where the garage is having an office built above it with solar panels installed on the roof. I have ran a 16mm 3 core...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
I have a detached garage with a 60 AMP subpanel which has lost power. I traced the failure to the wire running under the walkway via conduit...
Hi guys, Can I ask you a DIY question? I'm refurbing a detached garage and adding a garden building. Garage currently has a submain supplied by...
