Discuss resistance problems 2002 jaguar S type in the Auto Electrician Forum area at ElectriciansForums.net
Hi bit of a strange one as load is put on my electrical system the resistance across body earth increases if I measure negative battery lead resistance it rises from 0.1 Ohm to about 10Ohms
Any ideas how to fix
Cheers
Dave
Try measuring DC volts ,and may get to grips with what is going on.
Between Battery -ve and body work(earth tags) near things misbehaving !
( With them turned on.)
Whats miss behaving ,engine cranking ,lights ..other ?
(May be witnessing small DC pd in cable interfering with DC ohms measurement ... will go other-way/weird if reverse connections)
Hi,easiest way to find bad spot,is to get your DC meter (any little yoke,will do),put load on,and place probes across each side of any connection or earth strap. Any voltage measured,means a problem.
Hi MAF is playing up getting a DTC P0102 which I think is due to a high resitance on the ground wire which only happens with ignition turned on and cannot start the engine
Never known a MAF sensor to stop a car from starting, put it into limp home mode sure.
I think you may have other issues.
all terminals have been removed wire brushed down to bare metal greased and tightened back down see no PD across anywhere earth to earth
How are you measuring resistance with load on the electrics? If it's with a meter on ohms you'll get false results.
Hi using a mulitimeter manual tells me to test for resistance with ignition on when it is turned on the resistance rises
That could explain the change in resistance reading, the multimeter injects a small current to measure resistance, if a current that it doesn't 'know about' is flowing in the same conductor it will indicate a high resistance. As SZ suggests, it may be better to measure voltage to work out if there's a problem.
Poor starting and poor running could be lots of things , but as I suspect your MAP sensor has shown a fault and replacing it has not helped, it may be the EGR valve as the diagnostics are cumulative. A diagnostic sweep may save you hours of time searching for faults that are not there.
Is the air filter clean? Is it diesel?
only DTCs i am getting if for the MAF sensor ERG has its own DTCs yes checked filter all okay and no it is petrol
Cheers
Dave
As others have said modern engines have a long list of ways to go wrong. Just a couple of comments, it's best not to grease connections until after they're assembled and tested, grease doesn't conduct. I doubt that's a problem but one to bear in mind.
If you suspect the MAF, most engines will work pretty well with its cable unplugged, the ECU does a fair job of guessing airflow so seeing how the engine runs without it connected is worth a try, to eliminate the MAF as a problem.
Hi,there are other factors which will cause the ECU to assume a MAF fault,even if it is functioning correctly. This gives the ECU information regarding the amount of air,passing through the intake system,in relation to other factors.
For example,a blocked or restricted exhaust,could flag such faults.
You may require the services of a clued up dude with a proper machine,not just a code reader.
An old diesel engine was the simplest most reliable economical engine ever, just look what they have done to it. As for ecology , scrapping good roadworthy cars because they are electronically beyond economical repair does,to me benefit the manufacturers not the earth .
Sorry @PEG got me into the rant mode. :)
Reply to resistance problems 2002 jaguar S type in the Auto Electrician Forum area at ElectriciansForums.net
hi all, i have a problem of over charging on my 65 s type jag. i changed the voltage regulator for a new after market one same as what was on the...
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
Hello and Happy New Year. It's not starting too well for me, excuse pun. Since Friday December 16th, The 2.4l Duratorq diesel won't start...
I quite often contribute on other's posts about issues with RCD's, thought I'd tell you about what happened to me yesterday as a little bit of a...
