Discuss security lighting with 2 pirate sensors in the The Welcome Forum area at ElectriciansForums.net
A
Andrew Chronic
Hi can anyone help I have a security light with built in sensor and want to add another sensor but light only comes on once both sensors have been activated
I know I am not an electrician so was looking for professional advice wired up original light with built in sensor fine as it just has live neutral and earth and thought was easy as adding second pir sensor in circuit between power source and light but now I think about it make sense why only works when both sensors are activated does there need to be a second live from second sensor straight to light missing original sensor any help would be majorly appreciated
Typical reply I would expect from an electrician I'm not stupid ok I'm not qualified but not like I'm rewiring my house just fitting security light not even wiring it into mains just using it on a plug if your not willing to help or provide useful advice don't comment and thanks in advance to any1 that can provide me with useful advice ;)
It needs to be wired like this
Reply to security lighting with 2 pirate sensors in the The Welcome Forum area at ElectriciansForums.net
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
Hi, Some advice would be appreciated… I have 4 downlights in the bathroom and want to add a motion sensor to turn on just one if everything is...
Hi all, H.N.Y. The passive, affixed to a recently bought LED security light is rubbish, sometimes it works, mostly it doesn't, no matter how...
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
