Discuss Single phase switched fuse in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
Can you get 40A switched fuse for single phase as need price for them , can't find them online for guide, we link would help thx
What other ways are there around this , if there is.. Hefty price... I have 100A supply and want to split for two flats, giving 40A fuse each
Looks like what I'm after.... Looking on that site dis boards i can see modular enclosures . Can you use one with main switch and a 40A mcb???
Yes, not sure if you mean to have two MCBs in the same enclosure. If not then the first suggestion will be cheaper. If you go with separate switch fuses then u will also need a henley block. The wylex one suggested allows u to use MCB if required.
Reply to Single phase switched fuse in the UK Electrical Forum area at ElectriciansForums.net
Wallbox Fuse Box Lite Single Phase has anyone used one of these? I've installed one feeding a Pulsar Max, the Pulsar Max is set to 32Amp max. The...
Hi I have inherited a compressor with a single phase motor but its been stripped and I need to fathom out what's what.. I don't know if it even...
When there exists a single-phase transfer switch within a 3-phase distribution system, is it necessary for both feeds to the transfer switch to be...
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
Hi, I am Currently in the process of building an extension and my builders will shortly be getting their electricians to commence the first fix...
