Discuss Soffit lighting ? in the UK Electrical Forum area at ElectriciansForums.net
What light fittings are people using for soffit lighting ?
I have been using the integral evo fire ip65 and an integral lamp that i can get for around £8 per light.
Soffit lighting seems to be really popular and i am doing more and more of them so just interested to see what other people are using
personally, I use JCC V50 fittings. dimmable and selectable colour temp. around £16 apiece inc. VAT.
I also use "Lumary WiFi Smart LED Ceiling Light" soffit lighting.
Is WiFi outside any issue.
WiFi outside our property is fine. Philips wifi floodlights all work fine outside, have been reliable for years.
Wander round outside with you phone if you want to check! ? (Admittedly at soffit level might be an issue)
high IP ratings not needed in soffit unless roof leaks. my IP20 downlights have been in soffit for 10 years, no problems, not even a bulb/lamp replaced.
Reply to Soffit lighting ? in the UK Electrical Forum area at ElectriciansForums.net
Hi folks, I have been out to quote for a soffit lighting job. I have done jobs like this many times but usually only installing lights in the top...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
I am looking at installation of an architectural dimmer, that is will supply 6 channels, with 20A circuits each (2400W ea). Our hall has can light...
