Discuss Transformers in the The Welcome Forum area at ElectriciansForums.net
W
wil
I have a Dewalt 24v chop saw. The batteries have had it and after checking online, someone have converted his drill to run off a transformer by taking the dud insides out of the battery casing and wiring in a conection to a transformer so he could then slot the battery back into his drill and run it off the mains supply.
I'm thinking of doing the same thing so what I would like to know is, what type of transformer would I need and what would be the specs of it. I was thinking along the lines of 220v ac to 24v dc producing at least 350 watts to overcome the start up power of the saw. I know you can get 220v to 110v & 24v ones for building site work, but they are quite expensive,i there a cheaper alternative out there.
you'd need a 240/24V transformer. then you'd need to convert from ac to dc by using a bridge rectifier and some electrinics to give a nice smooth 24V dc.
buy yourself a dewalt drill or some other 24V tool that uses the same pattern batteries.
Yes we use 230v to 24vdc power supplies in control panels all the time, they have a 5a power rating but you can get bigger, or you can use 3 x 5a power supplies in parallel. The brand we use are Meanwell, they have them on eBay, to connect the outputs in parallel might require a diode though so they don't back feed each other!
A switch mode supply would cater for both 110 & 230V supplies, should be able to pick one up from flea bay for a reasonable amount. Personally I'd buy a new battery.
I must be missing something here....
What's the main reason for having a battery operated drill in the first place, oh yes, so you can take it anywhere, especially in places where there is no power supply available. So converting it to a drill that needs a lead and power supply kinda defeats the whole purpose....
why did you buy a battery one iin the first place?
there is always a genny if you need power for it somewhere.
a chopsaw would kill batteries quick
I worked on an airbase, they don't allow 240v stuff only battery, but now I'm retired I won't be shifting it about now, and yes you're right it does kill batteries quick so it's anoying having batteries run out halfway through a job. But as the saw cost me £700 I don't fancy chucking it and I know substitute Batts are £40 each, I'd rather spend the money on a transformer if one exists at under £80 (2 Batts min)
Reply to Transformers in the The Welcome Forum area at ElectriciansForums.net
have a set of lights that i would like to use plug over battery. have a few plugs and old sets with cables could Frankenstein together if doable...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi, I understand some basics about wattage, volts and amps etc but I am trying to decide what would be the most efficient system Situation - 2 x...
I'm working on a site in the UK where a joinery company will be installing bespoke vanity cabinets. The cabinets will have MDF/mirrored doors with...
Looking for advice for how much power I can reliably get from a dual battery system please (note it will be installed by a professional, I am just...
