Discuss Two switches for set of lights? in the UK Electrical Forum area at ElectriciansForums.net
Hello I have 10 spotlights in a room.
All 10 spotlights are operated by one switch.
I would like to split the spotlights into two sets.
First Switch to operate 5 of the spotlights.
Second Switch to operate the other 5 of the spotlights.
How easy or difficult is this to do? What sort of questions should I be asking myself for this?
Thank you.
you would need to know how it is currently wired to figure out how easy it would be.
the simplest way, and probably not the way its wired, is that there's a feed at the switch, and a switch wire going up to 5 lights, and another switch wire going to the other 5 with a neutral connection at the switch.
Age of house can sometimes give a clue as the standard ways of wiring lights changed over the years.
Older properties may have a central joint box... or there is a joint box accessible from popping out one of the downlights.
Whats above the room? another room, or attic?
However its done, you would need an extra core in the cable going to the switch to use as the second switchwire. Not always easy to add one in
There will be ways of doing it with smart switches or smart bulbs
It’s very unlikely that they have been wired the way you need for this to work. If they are switched together then most likely they all share the same switch line.
You can’t come to any conclusions until you get it surveyed by an electrician. But be prepared to start cutting holes in the ceiling and chasing out walls to run new cables in and the alter the existing wiring
Reply to Two switches for set of lights? in the UK Electrical Forum area at ElectriciansForums.net
Hi All, thanks in advance for any guidance you can provide. I will of course turn off everyhing at the consumer unit before doing anything. I...
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
Hi, I recently installed a smart light 2 gang 1 way smart switch. The two lights in question turn on. However on one of the 2 way lights I have...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
