Discuss Uk - Wiring double dimmer switch in the Lighting Forum area at ElectriciansForums.net
Hi All,
How do I wire my new double dimmer switch?
I currently have 2 lights in my living room operating off a double switch.
Same as the existing switch.
The browns in L1 go to L1 on each switch. L2 is unused on both and the looped brown across the Cs are looped across the wiggly line marked terminal in the middle.
Reply to Uk - Wiring double dimmer switch in the Lighting Forum area at ElectriciansForums.net
I have a led panel that i want to dim. It is dimmable but without a dimmable driver. I have a dimmer module and a dimmer switch as shown in the...
I fitted a dimmer switch by daisy chaining the dimmer switch to a normal plug. The challenge is the light flickers at random intervals. If I take...
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
I have carried out home wiring for 60 years as a competent person, for the last 20 years, I employ a local electrician to check my work and sign...
Hi all I've been changing the halogen downlighters in my house to LED's. I have three rooms that use dimmers, two of them have two switches each...
