Discuss underfloor heating do i need a CPC-Mesh in the UK Electrical Forum area at ElectriciansForums.net
just checking the regs 753.411.3.2 which state i need to use a conductive mesh connected to the CPC of the circuit.
I am installing a flexible heating mat from Warm Up in a kitchen and i dont see any mention of the mats needing a conductive mesh needing to be installed??
Is it a class 1 or 2 system? What does the manufacturer say?
Mesh usually incorporated within the heating cable itself. On some the cold tail is just standard flex, so not apparent as such, but the heating cable itself normally includes a braided earthed outer core. Follow MI's and all should be fine. Usually fit Prowarm but should imagine warmup would be similar. Give Warmup a bell if you're worried.
Reply to underfloor heating do i need a CPC-Mesh in the UK Electrical Forum area at ElectriciansForums.net
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
Up until now I have steered clear of heating systems. I now have quite a bit of work with a builder and will be expected to deal with the...
Hi there I need your opinion on this one, I need to fix mat 18sqm (200w). Client instead of one mat bought 2 mats (12sqm)+(6sqm) one thermostat ...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
m having a bit of an issue that is proving difficult to resolve. For 2 years I have been having no problems with my setup. I have a 3 zone house...
