Discuss Using Makita Li-on batteries on Dewalt body. in the Electrical Tools and Products area at ElectriciansForums.net
S
simopesh
It can be done. See pictures.
Where's your modding sensibilities, guys?! I want to know how that works...... I have plenty of knackered tools with great batteries, and good tools with knackered batteries, getting them to fit this way would be tidy. Also, would be cool to get three or four lithiums that fit all your tools with various 'adaptors' for all your tools.
Is that just the shell of the dewalt battery, wired to the makita clip diretly so it fits, then? I like it!
Yes, it is. All that you need is a knackered battery holder and an empty shell. Then you cut it, clean it with sand paper and then glue it with solvent cement. Make sure that the positive and negative are correct in case you want to use the Dewalt charger as well.
[video=youtube;39unmJWigmA]http://www.youtube.com/watch?v=39unmJWigmA[/video]
you should make a video of how its done.
tell you what the drills are bulky enough sometimes never mind extra bits hanging off them in a cupboard, think i will stick to the standard batts.
Well, my Makita SDS packed up after 2 years of heavy duty use so I was left with two healthy batteries that I wanted to put into good use.
Currently I haven’t got a body and faulty battery to use in order to create a clip.
phil does have a point, wonder if theres a way of slimming it down? still a good solutIon though.
maybe an umbilical cord type thing like you can do to the makita batts so they clip onto the belt rather than the drill. makes it real light and easier to work with
I thought about it though. It is like the power supply to the cameras flash in the past with a flex curly wire.
Yea that would just be better anyway even if you were using the original batts, and should be well easy to knock up. I may have a look at that....
I guess that would boil down to how often you would be switching tools or had to put the machine down but unclipping would still be easier and safer than a trailing cable.
Hi chaps,
I just made another one. (Well, not fully finished though) My mate had a few Ryobi batteries 2.4 amp Li-on and recently changed to Dewalt.
There are a few pictures of almost exactly what is done and tools/materials needed.
some werid and wonderful things you find on here! personally if id took the time gutt the orginal battery i would just buy some new cells and fix the orginal battery. You can get the cells used in nimh dewalts for about a £0.75pence if brought in bulk.
My mod that i did to my dewalt 36v flash light was pretty sweet, i brought the best led i could find a 700lm luxeon rebel tri-star from America and fitted it to the snake torch with a cpu heatsink the torch lasted for about 35hrs and brighter than the orginal. It was that good that someone nicked it. I was gutted i spend a fair few evenings doing it!
Reply to Using Makita Li-on batteries on Dewalt body. in the Electrical Tools and Products area at ElectriciansForums.net
This week at Electrical2Go we have a selection of NightSearcher products that are over 50% off! We even have a selection of NightSearcher Kanga...
Has anyone used Makita 40v tools? I’ve currently got Milwaukee but I’m having some warranty issues and a few battery issues. I’m thinking of...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
Our Halloween offers are here! Click below to see six of our current offers, which are available till Sunday midnight! *Cannot be used in...
Came across some tools by INGCO this week. from a distance thought they were Dewalt but was wrong. Got handed a powered screwdriver and thought...
5K
