Discuss Van stickers niceic labels in the UK Electrical Forum area at ElectriciansForums.net
Clean it first.
a good eye and a squeeze to push out any air bubbles and you will be fine.
Clean the van, isopropyl the spot where sign will go. Logo is small so you can hinge it on the top using masking tape, when you happy with the position peal 50mm of the backing off and fold it flat against the sign. Tape will hold the sign in position. All you need to do now is to run your squeeggee from left to right while gently pulling the backing down
After cleaning the area where sticker is to go, I lightly spray with water using an old spray bottle, e.g. windolene bottle. Then sticker can be moved about a bit . When satisfied with the position, hairdryer on low heat dries it out a treat.
Reply to Van stickers niceic labels in the UK Electrical Forum area at ElectriciansForums.net
Hi all. I have a small question about inspection interval labels. We all know to fit one of these labels with the relevant date upon completion of...
My 08 Renault Trafic has now done 212,000 miles. I'm the second owner, the first being the AA. It's never let me down in the 10 years I've had it...
I’m currently fitting out a gaming van that will be rented out for parties. The van will have 10 TV’s & 10 games consoles as well as some led...
I recently sold my Renault Trafic as it had done 214,000 miles and I also wanted something more economical. I bought the Citroen Berlingo LWB. A...
Does anyone know the size (diameter) of a reel of 2.5 twin and cpc cable ? i want to put a pole in the van but I don’t have any reels with me here.
