Discuss Vauxhall combo 1.7 DI in the Auto Electrician Forum area at ElectriciansForums.net
If you've got the fault codes (and their meaning) then start from the 1st one. The 2nd, 3rd ,4th etc may have nothing to do with the fault. If 1 sensor isn't working properly (eg. not sending a value to the ecu) then the ecu flags up a fault, other systems on the vehicle also rely on that value for them to trigger, no trigger and the ecu flags up a fault and so it cascades. This is from experience, Landrover wanted just over £1000 to rectify all the faults, so I did it myself. 30 minutes and some scuffed knuckles later no fault lights and it was running perfectly. And all because a wire to a wheel speed sensor had chaffed through.
Injectors??
I had a combo that I had intermittent starting issues with but like you once it was warm it would start every time. A bottle of injector cleaner and I never had that problem again.
The leak off / spill pipes may also be used to prime the fuel system if these are shot then you will struggle to start it
What fault codes are showing? Due to the cascade effect some fault codes are red herrings and can mask what is the actual fault
Hi,These engines have a well documented set of issues,that a quick trawl of the GM forums will enlighten you.
If there is any discrepancy between crank and cam sensors,or even not coded to show,check cam timing.
Chains jump,tensioners fail,and the drive sprockets are locked up by clamp pressure only,no keys
Them old Bedford HA vans never suffered from this...:conehead:
Reply to Vauxhall combo 1.7 DI in the Auto Electrician Forum area at ElectriciansForums.net
Hello everybody from Germany! I'm feeling sick with this car, it won't start, just very rarely...please help me out. Car: Opel Corsa C 1.2 2003...
Last weekend I experienced a weird electrical fault with my 2010 Peugeot Boxer Van. A little background - the van is a 2010 Boxer 330 2.2 Short...
Hello and Happy New Year. It's not starting too well for me, excuse pun. Since Friday December 16th, The 2.4l Duratorq diesel won't start...
I hear many views of people who believe that DPF's and CDPF's fitted to their vehicles are a problem and many people resort to removing them, or...
8K
Hi All, I'm a working man relying on his van to stay in business - but of course it's developed a horrible electrical fault that needs more...
