Search the forum,
Discuss What size cooker feed? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Cirrus, the RCBO in place for what?
are you saying they wanted the rcbo in for the cooker?
make sense i suppose, they'll all be on them soon!!!
I did a kitchen once and had to put in a 13A f/spur for the elctric range. As per aga instructions . . the thing was switched on permantly and just slowly heated up like a big storage heater.go figure?
Reply to What size cooker feed? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The electrician that installed my cooker circuit put in 10mm cable with a 32a fuse, a 45a cooker switch and 10mm cable to the backplate for behind...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
The customer has suggested from a previous electrician that the oven requires a new circuit installed . Upon viewing the instructions it is stated...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
