Discuss What would be your method? New lighting circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Leader
Evening,
I am rewiring my house and would like to put spotlights (around 10) in my kitchen. I was thinking loop in at the switch (from previous rose and to rose in next room) and then run the t&e cable (l,n & cpc) from one spot to the next to the next. Is this correct?
(Usual caveat- I'm still training/learning)
Carina
I've just rewired a large cottage and have used a variety of loop in at the switch and loop in at the light - both options perfectly viable, and can be used to suit your specific needs. In your case I think loop in at the switch makes good sense.
I didn't really think about separating the lights but that's a good thought.
I knew I could link in at the switch but I wasn't sure if I could run 10 lights off in a different direction to the rest of the circuit.
As it was just a quick question to check my thinking was right I didn't think members would mind me asking. Plus it's sometimes nice to hear different opinions from experienced folk. I think I've got my answer now but I'll ask my tutor next time. Thanks
Must be a big kitchen for that amount of light have you carried out a relux calculation before your spending money? Best advice is to use good quality fittings which are correctly rated for the environment and not buy whatever is on offer at the local wholesalers.
I did a bit of research and found a couple of methods for working out the number of downlights required. Ive got 177 square foot so I'm going with 9. The two outside rows will be on one switch and the centre row on another.
Reply to What would be your method? New lighting circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I'm currently in my year of my apprenticeship looking for some help with the 2 plate method (feeding the switch). I understand it up to the...
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
