- Reaction score
- 5,604
Hello,
A friend has asked me to replace a broken 2 gang switch in her garden which works electrically but is very badly cracked. One switches her pond lights and the other her pond pump.
I am not registered yet (will be in oct hopefully!) but believe it is ok to do a like for like change? I will check out first where the feed is coming from and if not RCD protected I wont do it, I'll also check that it is suitable cable and again am not going to get into this job unless it is just a simple change.
She presently has a normal suitably IP rated switch, see below
Should I fit this or one that is specifically for pond pumps/lights, see below
The rather fancy one just above has seperate fuses for each switch. Does the switch have to be fused?
Thanks.
Thanks.
