Discuss shower isolator switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
can the shower isolator switch be left ON all the time and the shower turned ON and OFF from the switch on the shower itself.
It should be. The isolator isn't intended to be a functional switch (although often used this way).
As above It's been a long running debate over the years. The isolator is exactly that an isolator not an on off switch.
What..... people actually use the shower isolator switch instead of the shower switch itself? Why?
I don't know. My background is industrial and mostly in three phase variable speed drives and motor controls.
The kit is fitted in enclosures, normally IP43 or better. The panel is fitted with a door interlocked isolator, actually a fuse switch, which may be three or four pole depending on customer specification and padlockable in the off position. The usual spec is load make, fault break, not something it would routinely be used for.
The fixed speed motor panels are fitted with motor rated contactors which are used to break the current in normal operation. On the VSDs, the drive is disabled before the contaactor is opened. In both cases, the contactors are AC3 rated.
Most if not all shower switches are manufactured to BSEN standards that would enable and permit use for functional switching. That said, it's not something I would do myself or encourage customers to do.
Table 53.4 contains info about devices, product standards, and their uses and functions.
You mean you don't know??!! :eek:mg_smile:
These showers do not heat the water as Instantaneously as we would like and to operate the shower switch we have to be standing close enough to the shower to be hit by a blast of freezing cold water until it warms up.
Some of us are a bit too long in the tooth and of too delicate a condition to withstand a deluge of ice cold water first thing in the morning - or at any other time come to think of it!! :wheelchair::15::nopity:
That is pure lazy.... What next,m switch it on via a Bluetooth fob....
Do you have to turn in your official Geordie membership card after a statement like that ? I thought you were all double hard barstewards up there that took their morning ablutions in the bathtub in the backyard after cracking the ice off the top ?
:tongue3:
:tongue3:
Aye well ..... I'm not very well just now. :sad_smile:
:tongue3:
Only in the summer , in winter we do it Geordies way.
Reply to shower isolator switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have an 8.5kw Triton Excite Plus shower, could there be a reason that it has been installed with a 50amp isolator switch, & not 40amp which...
Hi everyone My mira power electric shower is not doing anything when i press the power button. There is no led lights to check on the unit to...
I have just been called out to another burning shower switch.Upon removal the wires had been burnt and chared.One thing I've noticed on all burnt...
A pull-cord shower switch is located in Zone 2 of a bathroom, including the ceiling base containing the electrical connections. With a little...
Hi, after a bit of advice. Have tried a lot of plumbing and electrical shops but no one seems able to help. I have an Isolator/PSU 230v/12v. It is...
