- Jul 15, 2016
- 23,295
- 1
- 29,151
- 315,788
- United Kingdom
- Electrical Engineer (Qualified)
Seems a lot to me but if you get the work all is well and good. I think on domestics a charge per circuit is not always viable and maybe once you have done a few you will be able to put a rule of thumb charge list together. You could have a flat rate per dwelling according to the amount of bedrooms and then allow a charge for costings above this, for example a one bed you could assume 7 circuits for X amount and then say £20 for any circuit above this. You could also come up with a repair schedule for replacing accessories which are damaged but okay this with the client first. Always factor in some Report writing time.Do you think this is too much or too little? It seems not unreasonable to me, depending where in the country you are and your hourly rate.
