Discuss Domestics testing in an old house in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
That's Domestic testing for you Bradley, you win some you lose some, looks like you are just going to identify pairs logically.
Yeah good idea that's what I've been doing but just time consuming that's all just wanted to see if there was any other ways but cheers
I think as long as you keep calm, work logically and safely, it shouldn't be that gificult to pair the cables up, problem being you will have to work with the power isolated, which will be a bit of a bind for your client. H ave you any idea what type of cables you are dealing with, PVC/PVC, VIR or are they a miss match of sorts, if they are all different that could work in your favour for identification purposes. Let us know how you get on please.
I try to eliminate radials - lighting (check for borrowed neutrals) - rings in this order. I don't know if this is just common sense but getting rid of the radials makes finding the ring ends easier, for me anyway. Good luck and have fun. As @Pete999 says, keep calm and use cold hard logic.
And try a do a nice drawing so it's down on paper - then take a photo of the paper so it's in the cloud. I'll agree it is time consuming.
Do the obvious turn on all lights and do them first. Then get rid of the single point radials like cooker, immersion, shower etc. Then ring finals and see what is left. Check garden areas as well.
I use a cheap one from the bay for tracing power cables & keep the good one for tracing Alarm, Audio & CCTV cables etc. Saves a lot of head scratching.
Never tried the Martindale one, the cheap one is Chinese (I think) & the good one is an American test-um.
The test- um is a nice high powered unit for long distance tracing.
I was changing this yesterday (photo taken after I had disconnected 1 circuit:
I was unable to determine the circuits until I'd take a lot of it apart.... the 15A circuit covered all but 2 sockets in the house, the 3rd 5A fuse (fitted with 15A fusewire) covered the "missing" 2......
a right dogs dinner
Sorting these out takes time, patience and customers money to do properly
Turn off each circuit (if you can) turn one on at a time and check around house what's energised.
Plan of the house accessories on the circuits was what I was referring to @Les Macaulay
Remember to price jobs for this when quoting new jobs. I'm anxious to find out how to easily and neatly label the conductors.
Reply to Domestics testing in an old house in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I'd appreciate the wisdom of domestic sparks here... End terrace early 20thC house: Supply: I've not seen the likes of this before in a house...
Hi I have a Corby 7700 trouser press it is a 220w model, 3 years 10 month old. On Friday it stopped working, so I took it to the garage ready...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi, I'm a house builder that employs electrical contractors. I'm here to learn about the latest trends and issues so that I can ensure that...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
