Discuss Northern Power Grid Earth connection in the UK Electrical Forum area at ElectriciansForums.net
correct .Looks like TNS, sheath used as earth
ThanksI would assume that the neutral would’ve been identified on a new head. Would still say TN-S
Could always verify by contacting DNO
It's not check the brickworknext time you take pic ,please correct that it not on is side !
Oh yeah that'sits a yellow thingy .why ?
Thanks I did think it was TN-S it was the 2nd earth going into the service head that confused me.Looks like TNS, sheath used as earth
Looks like was TN-S but it now may have a link to the neutral to form a TN-C-S come TN-S.
If you've got TN-S, why add? I'd like to know what's gone on with the earthing system as a whole. Why 'neutral' the incoming cable sheath?Aye that's right. Northern powergrid have been doing heads this way round here for a couple of years now.
Yes, I do not like the idea of 2 mixed earthing arrangements here. TNS/ TNCS it should be one or other. IMOLooks like was TN-S but it now may have a link to the neutral to form a TN-C-S come TN-S.
Thanks Des, that makes sense.Perhaps Dave its not two earthing systems,it may be Tnc-s with the sheath of the original Tns now only acting as a exposed conductive part
In my area they have often spliced the cable outside and lost that earth path whilst they converted to Tnc-s
That's what I was intimating, Des. It is the easiest and cheapest way, after all. But, why no label TNC-S or PME?Perhaps Dave its not two earthing systems,it may be Tnc-s with the sheath of the original Tns now only acting as a exposed conductive part
--- Horizontal---?Aye that's right. Northern powergrid have been doing heads this way round.....
Hi the second fuse is for next door neighbours adjoining propertyDoesn't look like the second fuse carrier is connected to anything. Is the second earth cable going into the service head connected to the neutral ?
Thanks will test it tomorrowDoing a pfc and a pscc test and see what that tells you also?
However you'd need a tester for that.
Cannot tell from a picture. Sorry.
Hi thanks, I did telephone the DNO & they confirmed & said they would resend the installer out on Fri to label the PME stickers. I am going to call them on Monday as they never came.It will be TNCS, but it should have PME labels fitted
Your welcome it's the least I can doThanks for letting us know.
Reply to Northern Power Grid Earth connection in the UK Electrical Forum area at ElectriciansForums.net
