Search for tools and product advice,
Discuss Northern Power Grid Earth connection in the UK Electrical Forum area at ElectriciansForums.net
Hi I have just had an earth put into my property can anyone advise what type of arrangement it is? Many thanks
Aye that's right. Northern powergrid have been doing heads this way round here for a couple of years now.
If you've got TN-S, why add? I'd like to know what's gone on with the earthing system as a whole. Why 'neutral' the incoming cable sheath?
Perhaps Dave its not two earthing systems,it may be Tnc-s with the sheath of the original Tns now only acting as a exposed conductive part
In my area they have often spliced the cable outside and lost that earth path whilst they converted to Tnc-s
Thanks Des, that makes sense.
That's what I was intimating, Des. It is the easiest and cheapest way, after all. But, why no label TNC-S or PME?
edit.....and least safe.
Reply to Northern Power Grid Earth connection in the UK Electrical Forum area at ElectriciansForums.net
Hi. The question is..... can saturated ground affect earth resistivity testing equipment? Some days there's an unacceptable earth reading, another...
I’m not working on this… not yet anyway, but can someone tell me why there’s a fuse or a link on the earth here? The green wire is bonded to...
Evening Chaps As can be seen in the attached photo , the incoming supply cable has a Earth soldered to the outer sheath of the cable suggesting...
Hi all, just a quick one on an earthing arrangement for a radial circuit on a wooden workshop I have just had installed. I have run a 3 core 2.5mm...
