Discuss got some of these to fit this week. in the UK Electrical Forum area at ElectriciansForums.net
they're £24 from screwfix. 6 way board with just a 100A main switch is £23 . makes all RCBO boards ( up to a certain size) quite competitive. open forum, but everyone can see prices at the screwfux .
Alternatively, use them and you will fond out yourself.Let us know how you get on and what you think - one of my suppliers wants me to use them ....................... now, if BG did "bundled" pricing it may be a good idea.......
Alternatively, use them and you will find out yourself.
Just a thought
Just hope the terminal screws are not made of cream cheese like their usual offerings.BG mini RCBO.
look the dog's bollox. no functional E either.
My family run wholesalers are doing them for £12+vat a pop.
I really like the enclosures as they are very solid with plenty of room but then they fill them with utter crap components, and have I mentioned the terminal screws.Done a board the other day with these, there not to sad. I know BG aint everyones cup of tea but for the money there good in my opinion.
Fair point on the busbar, must be good for 500+ amps.I'd have to disagree, I always find them just as good as any [and often much more expensive] other brand. I've probably installed well over a hundred of these compact RCBOs already across a dozen or so new CUs, every terminal has been fine, they line up nice and straight and every test has turned out very well [Usually around 9-10 milliseconds on both x1 and x5 in my experience]. And as previously mentioned the BG busbar is the most substantial out there, far better than some of the flimsy rubbish that other 'quality' brands provide.
Really, i find the terminals alright. The built in level swings it for me as well. Saves a trip to the tool bag.I really like the enclosures as they are very solid with plenty of room but then they fill them with utter crap components, and have I mentioned the terminal screws.
Lewden?!? Where? Haha. Tell matey on the other thread he is about to change a temp db tomorrow as he can't get one lolI’m using Lewden RCBOs at the minute £10 each plus vat (no functional earth either) seem pretty good too !!
I had problems with these and ouside emergency lighting, did all dead tests and was fine left for a few weeks then power was put on and when i turned them on it tripped instantly so went and had a look and tested the circuit at the last light and had a direct short to earth and it was due to these rcbo all 5 of the circuits had the same but when taken the rcbo out and tested it it was fine swapped with a normal rcbo and all was good. So i basically don't like them
£12.50 here, can't get my head around it?just looked on TLC - £15+ vat.
if you mean the BG RCBOs, i don't thing so.Are they double pole like the SPS ones?
BG ones are £15.60 inc vat from TLC.
Look at that. Notice anything odd? Where is the test button? I can tell as I bought a couple the other day. It's right under the switch and while I haven't fitted them yet, I'm pretty confident pressing said button will result in a painful whack on the finger from the switch! Come on Wylex, surely you can do better than this!Ohh missed this one. Just as a comparison, Wylex compact DP RCBO's are £42.49 (SF). But I reckon you'll get them cheaper at wholesalers;
https://media.NoLinkingToThis/is/image//ae235?src=ae235/4766X_P&$prodImageMedium$
and if you do fond out yourself for goodness sake make sure no one is watchingAlternatively, use them and you will fond out yourself.
Just a thought
and if you do 'fond out yourself' make sure no one is watchingAlternatively, use them and you will fond out yourself.
Just a thought
A "proper" wholesaler will be more competitive ..............
Thats what a screwdriver is forLook at that. Notice anything odd? Where is the test button? I can tell as I bought a couple the other day. It's right under the switch and while I haven't fitted them yet, I'm pretty confident pressing said button will result in a painful whack on the finger from the switch! Come on Wylex, surely you can do better than this!
Reply to got some of these to fit this week. in the UK Electrical Forum area at ElectriciansForums.net
