Discuss got some of these to fit this week. in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
BG mini RCBO.
look the dog's bollox. no functional E either.
Let us know how you get on and what you think - one of my suppliers wants me to use them ....................... now, if BG did "bundled" pricing it may be a good idea.......
they're £24 from screwfix. 6 way board with just a 100A main switch is £23 . makes all RCBO boards ( up to a certain size) quite competitive. open forum, but everyone can see prices at the screwfux .
Let us know how they are in terms of alignment and sitting well on the busbar, Have had issues with BG of late with MCBs and RCDs not aligning too well and making it awkward putting cover back on.
It wont be long before they do them in bundles and preloaded boards.
Done a board the other day with these, there not to sad. I know BG aint everyones cup of tea but for the money there good in my opinion.
I really like the enclosures as they are very solid with plenty of room but then they fill them with utter crap components, and have I mentioned the terminal screws.
I'd have to disagree, I always find them just as good as any [and often much more expensive] other brand. I've probably installed well over a hundred of these compact RCBOs already across a dozen or so new CUs, every terminal has been fine, they line up nice and straight and every test has turned out very well [Usually around 9-10 milliseconds on both x1 and x5 in my experience]. And as previously mentioned the BG busbar is the most substantial out there, far better than some of the flimsy rubbish that other 'quality' brands provide.
Fair point on the busbar, must be good for 500+ amps.
£12.50 +VAT at TLC Direct, nothing wrong with them using loads of them, I bought a shed load of 6 rcbo pre loaded boards from screwfix when they were getting rid of them at £59 each!:)
I've had no problems with BG boards, a few years ago the "wings" of the dolly switch on the MCB's where too long and wouldn't fall into the off position in the event of a fault.
Hager prices in Northern Ireland are nowhere near competitive for single face Consumer Units.
That screwfix price for the compact RCBO is shyte though.
I had problems with these and ouside emergency lighting, did all dead tests and was fine left for a few weeks then power was put on and when i turned them on it tripped instantly so went and had a look and tested the circuit at the last light and had a direct short to earth and it was due to these rcbo all 5 of the circuits had the same but when taken the rcbo out and tested it it was fine swapped with a normal rcbo and all was good. So i basically don't like them
Hi,so what was actually at fault,then?
I didnt IR with the rcbo in i did a continuity and it was straight live to earth then disconnected it and ir tested and all was fine, and i dont know what the problem was as far as i can tell it was just the rcbo as i changed it to a standard rcbo with earth fly lead and all was fine
Ohh missed this one. Just as a comparison, Wylex compact DP RCBO's are £42.49 (SF). But I reckon you'll get them cheaper at wholesalers;
https://media.NoLinkingToThis/is/image//ae235?src=ae235/4766X_P&$prodImageMedium$
Look at that. Notice anything odd? Where is the test button? I can tell as I bought a couple the other day. It's right under the switch and while I haven't fitted them yet, I'm pretty confident pressing said button will result in a painful whack on the finger from the switch! Come on Wylex, surely you can do better than this!
Thats what a screwdriver is for :tongueout:
Reply to got some of these to fit this week. in the UK Electrical Forum area at ElectriciansForums.net
2 questions.. 1. Will the mini Starbreaker RCBO's fit in this board? Below is a picture of the board and also the type of RCBO I want to fit in...
So here is the thing Rhere is an old MEMSHIELD TPN+E Board that is pretty mich obsolete. The only place that sells their breakers would be Ebay...
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus...
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
Hi Family member has moved into this house which is about 110 years old. Bodges everywhere inc the electrics. We are just rennovating it and when...
