Discuss Emergency lighting for a beginner in the Lighting Forum area at ElectriciansForums.net
could someone please post a diagram for a 2-way keyswitch operated emergency lighting circuit.
Circuit includes one emergency light and 3 normal lights
Thanks in advance
looks like you have a N through the keyswitch ( D/P?) into the top manual switch which appears to be a D/P switch, not a 2 way.
You are approaching the right wiring but there are still a few areas that need attention.
You are drawing a set of four lights that are two way switched.
However in your original post you wanted a two way key switch, in general two way switching for normal lighting is not integrated into the key switch. So it would be useful to know which method is required.
Key switches tend to be available as either double pole or two way, but usually do not use the two way function of the switch for emergency lighting.
Assuming you want two way switched lights and one emergency light with a separate key switch for testing:
The Emergency light needs a permanent line; this line needs to be broken by the key switch, however it cannot break the neutral to the other lights or they would stop working during the test, which is not recommended.
The neutral is not involved in the two way switching or the key switch.
Perhaps if you were to work out the wiring so that the neutral is not switched at any point and the key switch only switches the permanent line to the EM light.
Also check the type of switch you would use to provide normal two way switching for the lights and use that switch in both two way switching locations.
You have the correct switch at the top of your diagram labelled 2-Way SW.
But I’ve drawn in the PL to the emergency light?
So what should I do with the neutral then? Obviously not put it thru the keyswitch then
correct.do not switch the N.no need for it. use wagos.
No reason not to use a double pole test facility it makes no difference.
but then by flipping the keyswitch, he loses the N to the "normal" lights..... dark side. the force is strong.
I think OP wants a 2 way circuit with 3 lights, plus an emergency light Ona key switch from the same circuit.
Moggy, we can’t do your homework for you... post a diagram of what you think it should be and we will tell you if you’re on the right lines.
Not drawn very well I know
MyWay - https://int.search.myway.com/search/video.jhtml?enc=0&n=78497c7c&p2=%5EBZC%5Exdm161%5ETTAB02%5Egb&pg=video&pn=1&ptb=D20FAD4F-0F28-43A1-83A5-F41AE8DF20A2&qs=&searchfor=Key+Operated+Switches+and+Emergency+Lighting+YouTube&si=&ss=sub&st=tab&tpr=sbt&trs=wtt
This may help the OP, at least I hope it does.
If you were to replace the greyed out section of your wiring with the added section, try and follow how the wiring would work for both the emergency light when the key switch is operated and for when the light switch is operated.
This version uses only one pole of the double pole key switch to avoid the possibility of having a light supplied by a line conductor but having no neutral conductor, not a recommended practice.
Just to note you can use one of the terminals in the double pole switch to terminate both neutrals cables in , there are also 2 way switches with a neutral terminal on them . I think hager make them
I guess I am, I have 2330 level 2 & level 3.
2391 and 17th but didn’t get a lot of work so went back to engineering but now taken a job in maintenance but wasn’t sure about emergency lighting so giving an example of this lighting issue as I have a problem with it on the stairs at work. Just need to understand how it’s wired correctly
This is what I came up with
Electrically fine and would work as expected.
However the testing of the emergency lights should not affect the normal lighting (Strima's post #17) and in your diagram the normal lighting would be switched off when you are testing, this is very useful to the tester for checking EM lights as they will be the only ones on, but would cause major inconvenience in a large enclosed office block relying on the lighting.
Reply to Emergency lighting for a beginner in the Lighting Forum area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
I tested a self test emergency lighting with three gears .While testing 2 of the gear doesn't passed 3 hour test but 1 Did Wit the same battery ?Why?
Hi folks, Can anyone recommend a reliable brand for emergency lighting bulkheads please? I have a job coming up to replace 30 odd units. I have...
Hello Got a customer who needs certification for a monthly emergency lighting test. What would be the best cert to provide them with? The NICEIC...
