- Mar 21, 2011
- 13,191
- 11,409
- 18,688
- United Kingdom
- Retired Electrician
If You are going to mount the CU on wood then just paint the wood in a fire retardant paint first.
Home | Rawlins Paints
www.rawlinspaints.com
I paint it in something like this, you can get it cheaper than quoted on the link.
I bought a tin a while back and coated a few sheets of ply, I then just cut out what I need for the CU then touch in the cut edges with the paint.
Its probably a bit over kill, but for a few extra quid it gives me peace of mind. I print off the data sheet to the paint and put it in with the EICR.
Why bother, the new CU being metal, means it won't catch fire
