R
RED~SIX
Had a quick call out to attend this evening. Currently closed but call was from a mum in need So I popped past with only my call out (light tools) in the car boot.
4 lights, one bathroom fan and a smoke alarm fed by a B6 MCB Protected also by an RCD.
Fault = no lights on the circuit working.
I quickly found the start and end of the circuit, so at the start I disconnected the loop so I could test the feed And work from light to light.
Using my fluke T5 the feed has the following:
Phase to earth = 240v
Phase to neutral = 35v
Neutral to earth 120v
the ceiling above is all a flat roof so no loft access.
I’m going back tomorrow for a proper look as I ran out of time.
Anyone had this type of fault before?
Lots of lost N's on here lately, must be catching.
You have a good apparent line to earth reading. Other readings are not so if you remove line and earth from your latter readings you are left with neutral.
Reactions: JAWS and snowhead
Strange post indeed
Doesn’t sound all that strange at all.
Reactions: snowhead
Was looking at post details
I will bell it all out tomorrow, just seemed like quite strange readings.
Simply just ran out of time today and this was not a planned job.
Any IR testing done?
Think more will be posted today
Nope - I was in the car and only has my call out tool kit.
I'm off work, but responded for a quick look for a lady in distress.
70% of posts have been removed from this thread. If you wish to start a thread on the riveting aspects of snow tyres please start another thread.
Just chatting on while we wait for more details :-)
Reactions: westward10
details to follow - I have not bee able to revisit as the lady has gone back to work, i'm going back on new years eve.
I have rigged her up some temp lights.
Must of been a nice few day over christmas then with no lights
As above, I rigged up some lights for her. also its only an extention thats affected so not the living areas.
Hoping for a update today on this
The OP I believe has established that it is the supply cable from the the CU to the first light point which is faulty.
Hopefully it will be a broken wire in the CU or a joint in between, not so good.
Email
Time zone
Last seen
Strange Call Out This Evening
RED~SIX,
RED~SIX,
