Discuss Safe approach to burying an unused T&E? in the DIY Electrical Advice area at ElectriciansForums.net
As title suggests, I've removed what a T&E has been used for, so it's now just a live cable. I've terminated it and boxed it (for now), but this needs burying and skimming over.
I think the right way according to regs is to trace it back, make sure it's dead then pull the cable out of the wall.
But the wall is freshly skimmed, so I'm wondering would it be OK to terminate it inside a block, wrap it with tape, and cover it with a metal pattress box which is the other way around?
No, it cannot be hidden in a wall. You could terminate it in a back box with a blanking plate though.
That surprises me, since it'd be a lot more protected from random screws than the cable itself is at any other point of the circuit.
Either way, I'm going to do what's safest here and take your advice, thanks
The point being that cables can only be run in prescribed zones. Once you remove the accessory it means nobody will ever know that a live cable may be buried there, and so may drill straight into it.
Ah ye that's a good point! That makes sense. Thanks again mate
Reply to Safe approach to burying an unused T&E? in the DIY Electrical Advice area at ElectriciansForums.net
Howdy DIY soldiers, first post here. My question comes down to whether it would be particularly unsafe for me to temporarily wire nut and tape a...
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
Hi all, Have a relatively simple question. Doing a rewire to make a circuit in a single room. My father is a retired spark, so no worries about a...
I don't "do" solar, but I've been asked to comment on an aspect of a new domestic solar installation by others. There is no overload or fault...
