- Apr 1, 2020
- 80
- 26
- 93
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
- If other, please explain
- None
As title suggests, I've removed what a T&E has been used for, so it's now just a live cable. I've terminated it and boxed it (for now), but this needs burying and skimming over.
I think the right way according to regs is to trace it back, make sure it's dead then pull the cable out of the wall.
But the wall is freshly skimmed, so I'm wondering would it be OK to terminate it inside a block, wrap it with tape, and cover it with a metal pattress box which is the other way around?
