Discuss How to wire three LED to main with one cable? in the UK Electrical Forum area at ElectriciansForums.net
Adrianna
Hi all,
I am new in this forum and would like to understand how to wire to the main supply x3 of the equipment that I attached as a picture?
I had a normal light and wish to have three of those leds instead.
Is it possible and if so how should I wire it?
Many thanks in advance.
Adrianna
Reply to How to wire three LED to main with one cable? in the UK Electrical Forum area at ElectriciansForums.net
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi all, I hope you're very well. (The switch goes to a 10W LED) Is the above wiring going to be safe please, especially given the way the...
I am installing 9 LED downlights each with an RGB bulb in (i will try attach pictures on them) - anyway I have been told that they need to be...
FYI --- This is a U.S. installation. I'm replacing a three way switch (the UK might more sensibly call it a two way switch??) with a Kasa Smart...
