Feb 11, 2018
169
30
103
32
scotland
Trainee Electrician
Business Name
Hi there fire rated down lights in a dropped false ceiling with no insulation and 2.5 watt LED lamps in cladding in kitchen with room space above not part of bs7671 but coding opinions if we do for safety ?
I don't quite understand your question, the grammar not technical aspect?
If they are fire rated then what is the issue?
They are not fire rated but have low wattage gu10 2.5 watt lamps in them on pvc cladding in a domestic kitchen with a room above would you still fire rate these under no thermal damage visual what so ever
Is this in a standard domestic dwelling, or separate flats?
Standard domestic dwelling up and Dow stairs lights on both up and down
Do the lights penetrate any fire barriers?
Doesn't seem to be an issue?
I'm not sure what questioning I'm answering, but as most down lights now are manufactured as Part B, E (& vapour), generally cheap as chips, seems no reason, why to fit anything else?
scotland
Trainee Electrician
Business Name
Fire rated down lights ?
The apprentice,
Midwest,
