G
goldie
Where cables have to be jointed e.g spurring from a ring final via a connection under the floor void where it will not be readily accessable in the future. What would be the best way to joint the cables as i understand a screw terminal junction box will not be acceptable .
Also crimp connections in a c/u. does it matter what colour crimps are to be used aslong as they are within their current carrying capacity. So for instance could i use yellow crimps for 1.5 mm2 t+e on 6amp m.c.b.
