Discuss cable jointing in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
G
goldie
Where cables have to be jointed e.g spurring from a ring final via a connection under the floor void where it will not be readily accessable in the future. What would be the best way to joint the cables as i understand a screw terminal junction box will not be acceptable .
Also crimp connections in a c/u. does it matter what colour crimps are to be used aslong as they are within their current carrying capacity. So for instance could i use yellow crimps for 1.5 mm2 t+e on 6amp m.c.b.
Best use a joint box with push fit connections as these are maintenance free! Can get them at any wholesaler.
Use red through crimps for 1.5 t&e, blue through clumps for 2.5 t&e and yellow through crimps for 6.0 t&e.
I have used Line Maintenance free junction boxes (forum sponsor...) and like them.
For crimping I'd use blue or red on 1.5mm2, can't remember the size for yellow but I suspect it is too big for 1.5mm2. (4 to 6mm2 rings a bell?)
EDIT: Monkey beat me to it....
Thanks for the help!!
would it also comply if i were to use a joint box with screw terminations placed in the floor void if i gob the enclosure up with a compound?
If you want to use a jb you really should try those line ones from the forum sponser, i haven't used a screw terminal jb in years, the line or wago are so easy and they are mf
I have to say that for permemant underfloor applications you can't beat the Ashley Hager products.
Not if you do it properly and offset the crimps so they're not all in one place and make the cable look like a snake thats eaten a buffalo
and securing the cables ??
ashley has cable clamps ?
so you will need to fix cables securely ?
time you have p!ssed about you might has well fitted a hager box in 2 mins flat !
:dizzy2:
Reply to cable jointing in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have been going round in circles with this question. I just cant seem to get an answer remotely close to the options. Continuity of a ring...
Hello, I am posting to ask what is the best way to remove some Virgin cables that are clipped to the side of my bungalow, and the associated...
5K
Hello All Strange question for you, I know you don’t have crystal balls :) but can anyone give me any clue on the following… I have mid eighties...
