Discuss DeWalt impact wrench selection for containment installation in the Electrical Tools and Products area at ElectriciansForums.net
Good evening all,
I'm thinking to buy a Dewalt impact wrench for containment installation, sometimes can use for car tyre changing. Which size (1/4", 3/8" or 1/2") are more suitable? Considering DCF922 1/2", what's the difference with DCF923?
Regards,
Andy
As above, it would be limited to a small number of tasks when installing containment and those are easily covered with a middle of the road impact driver (which also covers many other tasks, weighs considerably less and fits in tighter spaces due to more compact form).
A lot of recent impact wrenches do have settings to limit torque, but it's not a tool I'd be rushing out to buy for this job.
As for differences between Dewalt tools? Afraid I can't help with that and would advise you ask a passing joiner 😋
I think there’s a tendency to seize hold of the fact that a lot of places sell combi/drill and impact as a pair and assume that the impact wrench is therefore the ideal powered screwdriver for all situations.
It’s actually too vigorous for a lot of tasks, and while can be handy I don’t consider it an essential tool.
A good drill/driver and a good SDS drill on the other hand are both essential. Followed by a multi-tool!
A battery SDS drill is handy for attaching fixings to brick walls, etc. Think of smaller drills like 8-10mm for a plastic Rawlplug and woodscrew+washer, or maybe up to 10-14mm if you are putting in a bolt (expansion or chemical anchor) for something like channel strut, etc.
As above, a typical impact driver will just rip off smaller fastenings and make a complete mess of stuff. Having said that, one of my most useful tools turned out to be a 1/4" hex impact driver that I used with hex-shank drill bits, hole saws for 16/20/25/32mm fixings, etc. This one is great:
You might look for a kit with it and batteries and charger, I got this originally:
However, the normal "combi drill" is not used that often, but it has been handy for drilling without the hex-shank bits (they are cheaper and easier to get all sizes) and also for larger hole saws for duct pipes going in to plastic boxes, etc.
But be warned - that small impact wrench will happily shear off M6 fasteners if careless for a moment, so keep on low setting only use it for tightening larger stuff (M8 bolts or really big screws, etc) and NO MATTER WHAT do not use it on electrical terminals!
OP was asking about an impact wrench (1/2" sq drive and 600-2,000 NM torque) as opposed to impact driver (1/4" hex drive and 60-200NM torque), but the latter would most certainly be one of the essentials for a lot of containment work. Impact wrenches also have their place, but drivers will cover the majority of it - the only job I'd even consider the wrench useful for would be setting large thunderbolts, but to date my driver has never failed on this task. Maybe I need bigger thunderbolts 😁
I'd also be wary of sets offered by the well known tool brands. They're often good value, but just as often contain tools from the lower end of the manufacturer's range. Generally I'll compare specs, settle on the ideal model of a particular tool and then find the best price to buy it body only. Biggest and most powerful isn't necessarily best and for electrical work the ideal tools can be middle of the power range, but with alloy gear housing and metal gears (a surprising number are nylon), although metal gears these days are generally sintered metal. Many tools from the lower end of a range are surprisingly good, but much depends on what you expect to do with them - a £40 drill is going to shear its gearbox clean from the body if you try cutting with a 210mm holesaw, but conversely a very powerful drill will weigh more than necessary and be too big for some of the tighter spots we find ourselves working in.
If you're only starting out I'd advise against hasty power tool purchases, unless the employer expects you to have some specific tools, an instead look at the work you're doing and tools others are using to help make a more informed decision.
You would be better off buying a ratchet rather than an impact wrench.
My impact wrench only gets used for changing wheels etc.
Big advantage, it's lighter.
Examples:
Reply to DeWalt impact wrench selection for containment installation in the Electrical Tools and Products area at ElectriciansForums.net
Hello. Is it possible to find a compatible rotor for an electric motor based on the dimensions of the original rotor? The manufacturer Fein says...
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
I've seen a lot of people on here addressing the online qualifications for access training but not talking about the Apprenticeship aspect. I've...
