Search the forum,
Discuss Problem with bathroom extractor fan in the UK Electrical Forum area at ElectriciansForums.net
Elvistcb
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one a few weeks ago. That then blew and he came back and said that the extractor wasn't fit for purpose as it is wasn't powerful enough to get rid of all the steam after a shower. he said that he would need to install a powerful device in the loft and just have the vent for it in the bathroom ceiling. The cost will be £990!! He also said that the new fan blew because it tried to suck out the steam and it wasn't powerful enough so the steam turned to water and flowed back down the vent and shorted the electrics! This sounds like nonsense to me! I think its more likely that as they have had a problem in the past of rainwater getting into the roof where the extractor goes through, its more likely that rain has got into the system that way.
Any advice or info would be appreciated.
thank you in advance
Not necessarily nonsense. It is a common problem at this time of the year for condensation to form in ducts from bathroom extractors. This is because the duct will be cold, it is after all direct to outside. Push a load of warm moisture laden air through it and it will immediately condense. I have had to remove a full bucket of water from a long horizontal duct in a roofspace before. In the case of a vertical duct all this condensation will run back in to the fan. 'Normal' axial fans are designed for short ducts straight through a wall, and are not powerful enough for long ducts. For this inline or centrifugal fans are required to create sufficient air pressure. It may well be that your electrician is correct and the best option is an inline fan and an alteration to the outlet and ducting, although this is not what you want to hear. I would advise getting other quotes for the work though.
You need a condensation trap fitting on the fan duct close to the fan
Had problems like this a number of times on one flat if the prevailing wind was in the same direction as the heavy rain the bathroom would get water in the fan and on the floor due to the height of the outlet and it's position on the building it was difficult to access it to change it fitted the condensation trap and connected it to the soil stack going through the loft and the problem was fixed this also fixed the pipe condensation running back to the fan due to the long duct run in the loft
Reply to Problem with bathroom extractor fan in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
HI There, I would be grateful if you could help me, I have a very long duct between the bathroom and extractor outlet vent and for sometime, the...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
I've installed a replacement bathroom extractor fan. Pic on the left is the old one. Pic on right is the new one. Wired the same way but the fan...
