Discuss 230v neutral to earth ? row of lights gone out mcb not tripped in the UK Electrical Forum area at ElectriciansForums.net
M
marlon89
Hello all,
I have recently attended a job where a row of lights have gone out and was advised and seen for myself when i got there that no breakers have tripped.
First i took the cover off of the panel with the mcb's that feed all lighting circuits in open office area , and checked i have 230v on load side on mcb , which i did have on all mcbs to rule out a faulty breaker. I next went to the nearest light fitting to the riser where dbs where and found 230v at fittings with lights not working (all on sensors ) and ballast units also had 230v.
I then was advised (by site engineer) that sometime in the past these lights had lost power and had been rewired by someone ?? not sure if they were qualified or not ... i then went to a room at the end of the office area where he advised me they repowered this lighting circuit which has now gone out but power still there couldn't see any polarity faults but didn't get a chance to check all fittings as was in working hours of a office.
At the end fitting i was getting 230v between N-E and i haven't come across this before would appreciate any help :)
Yes on the same fitting one of the furthest away from dB's , what I don't get is why are none of the lights working if ballasts and main connections in fitting have 230v ?
230v N-E and L-E at fitting with lamps not working
Crikey. It's a circuit with a supply, a switch and a lamp, and it's broken somewhere. Ask yourself where. It doesn't seem to be the line...
But these lights were working fine up until Friday no one has touched wiring recently , but thanks guys . So it may have come out one of the fittings or sensor's ? Can't think of any other options that could have happened ? as no one has touched circuit recently to my knowledge.
I was getting 230v N- L at fitting as well .. so how can it be broken ?
230v L - N 230v N-L and 230v N-E row of lights out mcb not tripped .
Re-read what you typed and confirm whether it is what you meant to type!
Lol, I guess it might be possible with the right (read 'wrong') digital tester and no 'low-z' range ;)
Yes this was what I was getting !! 230v N-L 230v N - E and 230v E to N .
If I was getting not 230v between L and N then obvious it's a broken neutral but this is what iv been writing and people are saying it's a broken neutral when it can't be !!
Reply to 230v neutral to earth ? row of lights gone out mcb not tripped in the UK Electrical Forum area at ElectriciansForums.net
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
