Discuss 2391 or 2392 ???? in the Canada area at ElectriciansForums.net
Hi
I completed 2330 level 2/3 2008 and am i doing 17th edition update in july.I have limited domestic exeperience would it be advisable to do 2392 1st then 2391 after or get some more inspection and testing experiance and study hard and do 2391 1st.Undersatandably doing both will be very exspensive
Upto to you tucker, legally you don't have to have a qualification to inspect and test, but it does help as some cotractor insist you have it. Might be best to get your 17th edition and see how it goes, cos at least you'll know what you're looking for when you test.
Some colleges do additional practical sessions for inspection an testing which would give you some general knowledge of how to use the meter etc, then once you've done some testing in a job, go for an inspection and testing qual.
I put my 'basic' students through the 2392, and insist they pass it before i will consider them for the 2391
the way i look at it, most people fail the 2391, wheras i have very high pass rates for the 2392 (its only a level 2 qual), so at least you get a formal qual in inspecting and testing, then go on to the 2391 when you have got more time on the meter
and remember, you pays your money, you takes your choice
thank you
had 5 lives for you reply
Hi all
I understand testing and can do dead and live tests as i have done this with a domestic spark .i have passed the 2 written exams ( 2.5 hrs each one ) on level 3 2330 ,what is the written exam like on 2391 ?? what is involved in 2392 what is the difference between them and the rough cost thanks
thank you
Hi all
we charge about the same for each course (about £995)
2392 is an initial verification of a small single phase board with a ring and spur, cooker circuit, one 2 way lighting and one radial to a socket, done in two hours, including the EIC
then its a 45 q multi-choice online closed book exam, its level2 and is NOWHERE near as hard as the 2391 exam, which is curently sitting at about a 33% pass rate:eek:
Reply to 2391 or 2392 ???? in the Canada area at ElectriciansForums.net
Hi everyone, Sorry, I won't take much of your time. To cut a long story short, I am newly qualified and have domestic installation/commercial...
hello , Just a note to see if anyone been in the same sort of journey as me? I wanted to retrain as an electrician at 40 and on bad advice did a...
Hi all. I did my level eal diploma few months ago and now recently passed my 2391-52 exam so I have the inspection and testing qual also which is...
In my line of work it's very rare that I ever have to change a DB. I'm largely in maintenance; occasionally have to add new circuits etc. so in...
NICEIC Certification Scheme Getting accredited to
Looking for some advice regarding joining a CPS. I've been in the electrical industry in various roles for nearly 10 years. I started my...
