Discuss £360 wot do you think in the Australia area at ElectriciansForums.net
mcm
What would people say was a fair price to
Change 2 down lights for shower ones
Look at fault on other down lights
Supply and change 2 pir lights
Fit 2 rcbos to lighting circuit and sockets.
Investigate light fitting not working and put right
Certificate all work carried out
I think this is a fair price what do other think.
I think i would be more likely to quote a price for the "known" work and an hourly rate plus parts for the fault finding. If you have said "i will put it right" you could end up with little or no profit if it turns out to be major problem.
If your also supplying the RCBOs as well as the PIR fittings then I think you are just about right.
There is quite a bit of fiddling about there, if all goes well it could be a short day of perhaps 4-5 hours, or it could be all day depending on the faults and what you need to repair them, ie perhaps replacing those broken downlighters.
I would have charged for the day which is about 240 pound then you have your materials so 360 maybe just about right. If there was a chance of more work and I finished the job early, then I would discount my day price by say 10-15% it looks good to the customer. If it is just a one off job then you may just want to charge the whole day, it is a suck it and see thing.
I don't quote for fault finding, made that mistake before when a quick call out at the end of the day saw me there for two n half hours until it was dark then nearly all of the next day and the morning after that, eventually I found the small nail at the back of a book case that was just penetrating T+E where someone had pushed a book in just a little bit too far. The nail only tripped the circuits when the cable 'warmed up' and had been on for abit (guess thats due to expansion or something). All for the price of about 50 quid. Luckily I had a nice customer who was so thankful that she gave me an extra 50 quid on top. Still £100 for nearly 2 days work isn't alot. Hence all fault finding is at day rate and takes as long as it takes.
Reply to £360 wot do you think in the Australia area at ElectriciansForums.net
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
Currently I’m using freeagents platform for invoicing and it’s decent and gets the job done but it’s lacking a few features. Firstly I want to be...
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
