Discuss 5x 1.5mm - 25mm conduit in the UK Electrical Forum area at ElectriciansForums.net
Thanks wasn't sure if the reduction in CSA because of the bush would cause an issueYes you can
It wants me to type more letters so yet again
Yes you can
For aesthetics only, cables are running above a plasterboard ceiling then dropping down to accessories in metal conduit, seems to be the fashion nowI find myself asking why you're running T&E in conduit when that conductors aren't flexible?
If that is the case why not put an MF connection so that you have flexible conductors for the conduit? I get that OSG allows for flexible or solid conductors but it wouldn't sit right with me, probably just me though.For aesthetics only, cables are running above a plasterboard ceiling then dropping down to accessories in metal conduit, seems to be the fashion now
Why does it not sit right with you? I'd be very interested to know why solid conductors are not suitable for conduit, as it would render every single home in northern ireland unsuitableIf that is the case why not put an MF connection so that you have flexible conductors for the conduit? I get that OSG allows for flexible or solid conductors but it wouldn't sit right with me, probably just me though.
Reply to 5x 1.5mm - 25mm conduit in the UK Electrical Forum area at ElectriciansForums.net
