Discuss Adding to current garage setup via fused spurs in the DIY Electrical Advice area at ElectriciansForums.net
J
jim3010
Hi guys, I'm trying to extend
what lighting/sockets I have in my garage.
Currently I have a 2.5 t&e
coming through the brick to what feeds 1 double socket and 3 tubelights. I'm not
sure wether this is spurred off a ring main or is part of a radial circuit from
the house. Anyway I want to add another 2 double sockets and 1 more tubelight.
Here are some pictures. This is what I currently have
And this is what i'm proposingtaken the circuit is a ring main
Would that be acceptable?
So long as you feed the 5A SFCU from the load side of the unswitched FCU and you have the means to test the circuit for safety afterward in accordance with the wiring regulations then that should be OK.
Try and avoid junction boxes if you can, one more point of failure.
Reply to Adding to current garage setup via fused spurs in the DIY Electrical Advice area at ElectriciansForums.net
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
Evening all, I’m looking to install an outside light as a spur from a socket on a ring main. There is already a spur from this socket supplying...
Hi everyone, I've got a garage with a circuit that looks like this: I believe it's a radial circuit coming out of the MCB with a current...
