sambotc
Even though it is capped at 3.6kWp under G83, surely you would have to advertise it as 4kW or am I missing something?
kWp is the standard unit for the rated output of the panels under standard test conditions only.Yes but technically speaking your car could do the MPG as proven in tests. Technically speaking your 4kWp will never peak at 4kW ever.
It's a hornets nest I would rather not disturb and the way I see it is as long as you sell the system informing the customer that it is capped at 3.68kWp I don't see it being an issue, but those window companies with useless salesman might be misleading their customers technically.
don't get me wrong, it will happen sometimes, but usually only for relatively brief periods as the panels will warm up in 1000W/m2 of sunlight unless there's a howling gale, or the air temperature is seriously cold.
