Discuss Advice on outdoor lighting setup in the Lighting Forum area at ElectriciansForums.net
m1keyboy
Evening All,
Just looking for a bit of advice on what I would assume is a fairly straight forward domestic lighting setup?
I'm looking to install two outdoor lights at the front of the house. I want these these lights to work in tandem, and come on automatically when it gets dark so I assume I need a dusk/dawn sensor. I then want the lights to turn off at 11pm, and switch to being triggered by a PIR sensor until it's dawn, then off until dusk again. It would be nice to be able to manually override this and switch everything off if we're away from property for a period of time.
Anything else I need to consider here? Is this sort of setup fairly simple for a professional? Any recommendations on switches/sensors etc?
Cheers
simple job for a sparky. timer and photocell for the lights to come on from,say,4pm to 11pm but only if it's darkish: PIR to activate on sensing motion, independently of timer: On/Off isolator to disable: manual override switch for manual operation. Can also add smart control to switch from cellphone, with cameras for security.
I have a similar requirement, but I've gone down the smart home route. I know it's more expensive, but as we move towards more and more home automation, these things will become commplace. My solution was to pair a philips hue outdoor motion sensor with my samsung hub and then have smart GU10 bulbs in my outdoor lights. That way I can avoid having an unsightly PIR sensor (personal choice) visible on the light fitting and I can use the motion sensor to trigger a number of things and can program a multitude of IFTTT scenarios.
Reply to Advice on outdoor lighting setup in the Lighting Forum area at ElectriciansForums.net
Hi, Some advice would be appreciated… I have 4 downlights in the bathroom and want to add a motion sensor to turn on just one if everything is...
I have outdoor lights that are controlled by dusk sensor and then timer (for OFF) on the right of the picture. The switch to the left of the box...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
hello all. I am trying to add led strip lights to my boat trailer. I have marine grade submersible lights. I will have them running parallel to...
On either side of my front door is a motion sensor wall light - it looks like both lights operate from one light switch inside the house. The...
