L
Lc1
Hi,
Does anyone know if you can model a 125A 4 pole bus bar chamber feeding fused switches on Amtech as a distribution board ?
Thanks for that. Do you know how to model a bus bar chamber on amtech as I am struggling with the help manuals.
Thank you for the reply. I have taken a cable form the main board to a centre feed and then to a busbar. I have then taken tap offs from the busbar for the fuse switches. jut to confirm that this is the correct way to model. Thanks
Reactions: Nigel
Yep. Sounds correct to me.
I’m just trying to set up a model of a switchboard on amtech. Not been on an Amtech course, sort of self learning.
So you have intake, switch fuse as the main switch feeding a bus bar then switch fuses. Is that correct?
We have a fused switch in the main switchboard cabled to a bus bar chamber off the bus bar chamber there are fused switches. Not sure how to model the fused switches
All you can do is do the main board and number each switch fuse as a way and make a sub-main off that. If you click the looped supply it creates a sort of bus-bar outlay.
  • Disagree
Reactions: 1 person
Thanks. I have taken the main switchboard. Cables down to an end feed. Created a bus bar off the end feed and taken a tap off for the fused switch.
Thanks.
Reactions: Nigel
Sorry to bother everyone again. But if we have two sections of a switchboard connected by a bus coupler, how do we model this on Amtech? Would we take a tap off from one board and use this to feed the other side?
Amtech question on modelling
Thread Tags
Lc1,
Lc1,
