A
a.e.s
Hi guys, I am after bit of advice regarding calculating the anticipated maximum demand.
I dont know a lot of details about the install apart from: It is a 3 phase pme, 100A cut out. Light industrial use. I am calculating small power and lighting only, no mechanical. Lighting will be LED. The area of usable space is approximately 1000m^2. I have calculated the combined small power and lighting to be approximately 20.6W/M^2. So Anticipated max demand is approx 21KW.
I think that I have overestimated a little bit because of the fact that LED lighting will be installed throughout, though I dont think that is necessarily a bad thing.
I am interested to see if anyone thinks that I have made a judgement error and it is in fact much higher/ lower than my calculation.
I am also interested in hearing other peoples methods for this type of calculation.
Regards
Regards
