impish15
Trainee
- Reaction score
- 27
@HappyHippyDad great thanks for the link
Discuss Any advice on rewires? in the UK Electrical Forum area at ElectriciansForums.net
It's how it used to be done in the UK, electricians first fix consisted of marking out the route for the conduit and a specialist did the dirty work, this was all before some bright person (did not want to say spark) came up with the idea of using ceiling board as it was called, on the walls because it was faster and got rid of a two or three day wet trade, studwork walls cause more problems than they are worth, especially sound insulation and fixings for heavy items.Over here a lot of chasing gets subbed out to companies who specialise in the dirty art of wall chasing, but then we generally need to run deeper tracks as all cables are contained in conduit (mostly round) and the majority of walls are block and floated out in plaster. Dot and dab is very rare and boarded walls are usually a cheap fix to cover old, boss plaster.
Have you used the triple blade @nicebutdim ?I'd spend the money on a replacement triple blade, before going back to twin blades and chisel.
Yes and it was the primary reason for buying this more robust chaser. There are plenty of cheaper options out there which are perfectly capable of powering two discs through a range of materials. I liked the idea of cleaning a chase in one go, with a minimum of fuss.Have you used the triple blade @nicebutdim ?
I'd be interested to hear from anyone else who has used it and if they like it.
I think you are right and I will probably buy another one. It saved a lot of time over the last 2 years and would certainly have paid for itself
With the ad in the middle of your post it says "I actually make" and nothing else, I was unable to see your post in full until I quoted it, THIS IS BECOMING MORE ANNOYING EACH DAY, ADDS IN THE CONTENT OF A POST WHATEVER NEXT, ARE YOU LISTENING ADMIN?I actually make sure I have a spare triple blade on the shelf, I cannot imagine using the machine without it.
Completely agree Mike. the ads are now in the posts, actually blocking the content from view. They only ever get worse.With the ad in the middle of your post it says "I actually make" and nothing else, I was unable to see your post in full until I quoted it, THIS IS BECOMING MORE ANNOYING EACH DAY, ADDS IN THE CONTENT OF A POST WHATEVER NEXT, ARE YOU LISTENING ADMIN?
Reply to Any advice on rewires? in the UK Electrical Forum area at ElectriciansForums.net
